Jacpac opinions
Winnipeg, Manitoba, Canada
I had a pancaked 35" yesterday after work - it was a big hassle to get a compressor and fill it up. The tire has given me grief 3 times now in as many months.
Anyway, I started thinking about on-board air. I'm not really interested in a permanent system as I would only be using it for emergencies and some rare off-roading. Coincidently I saw a Jacpac system on sale at Canadian Tire and thought this might fit the bill.
Does anyone have any experience or opinions of the Jacpac system (JacPac CO2 System - Home) for use as an emergency tire inflator and air tool driver?
Thanks!!
You *might* be able to reinflate four 35" tyres from 15psi ==> 35psi with the 20oz cylinder.
-B-
I saw that add as well, I'll ask my P.Eng at work, as my very rough calculations shown it would not even come close to airing up 4 tires. But for one tire it looks like most definetly, assuming the 20 oz. cylinder.
Nope, but it does answer the bigger question posed. Options are always nice. :D
response from jacpac
I emailed them and asked if their system could fill four 35" tires (I failed to mention a PSI range), and here is the response:
Many thanks for your e-mail! Our JacPac system will produce 6.3 cu ft of air from a 9 oz cylinder and 12.7 cu ft of air from a 20 oz cylinder. In general, a 20 oz cylinder can fill one average 33” truck tire in approximately 3 minutes. As all tires vary, we do not know the exact performance you can expect by using our system on your size of tires, but a 20 oz tank should be able to perform the task. Please be clear this system will not fill 4 tires from one 20 oz cylinder but works well for topping up 4 tires if needed. If you should have any further questions, please let me know. Thank you!
Regards,
Shannon Benson
Key Customer Support
Supplierpipeline Inc.
Tel: (519) 579-6584, ext. 236
Fax: (519) 579-7650
sbenson@supplierpipeline.com
