Hello everyone,
I recently purchased a Toyota Land Cruiser J100 4.2 diesel (2003) and I am experiencing an electrical issue with the power windows.
The rear power windows (both left and right) do not operate at all. I have currently removed the two rear window fuses because, when installed, they cause a parasitic battery drain. Additionally, with those fuses installed, the front power windows also stop functioning.
Despite this, in both rear doors the speakers, interior courtesy lights, and central locking actuators are all working normally. Only the window motors/regulators are inoperative on both sides.
This suggests that power and communication to the rear doors are present, but the window circuit itself is affected.
Has anyone encountered a similar issue on the J100? I would appreciate any insights regarding possible causes such as the power window relay, master window switch, body ECU / integration relay, or wiring loom issues (especially in the door hinge area).
Problem is only on rear windows, front windows work good.
Thank you in advance.
