OK, it is hard to explain. It is a zchoo, zchoo that coincides with acceleration and deceleration. It did get a bit more noticable after I got the F&R ring and pinion done and complete front axle rebuild with OEM parts. What ever that means? It is much more noticable when under load, still there coasting but not as bad. It's hard to tell for sure but, doesn't seem to be there in LO range..ran through all gears sounds smooth and good. T-cast oil has been flushed with the cheeper stuff now running Redline full syn. Rear of T-case has been off I don't know why but not by me. There is orange silicone. The noise has been getting worse. more noticable when the cruiser is cold. And also after a 150+ miles of offroad.
What I have done:
Coasting in nutural still there not as bad.
Coastiong t-case in nutural even better.
Removed front DL still there.
Removed rear DL still there.
Both drivlines have all new u-joints.
I'm leaning to the t-case but no idea what it could be going on in there. Other ideas or what you think it might be in the t-case would be great. It is hard to put into words I hope I explained it well enough.
I know the tranny could be the culprit as well. But just runs great, shifts great. But if you think of anyting in the tranny it might be please tell.
If there is anyone in the Boise area that could listen, or has experance with something like this please let me know.
Thanks all, Phil
What I have done:
Thanks all, Phil
