it's quiz time...
Phoenix, Arizona
...what are the three empty plugs for that are under the center console?
x12
A vacumn to go with all the food debris you got going on there. Sheez....
There is an unused plug in the passenger side rear quarter panel (near the stock "subwoofer"). Any ideas on that?
/hijack over
Isn't the pump up front under the hood? However, you did just answer my wondering about why there is a clear rubber hose on that side with no washer fluid in it!
Good point. Maybe power to go to the rear passenger side wiper for the ambulance doors.
That's what I was told.
This is what I've figured out so far:
1. Plug under center console - JDM center cooler/freezer thingamabob
2. 4-wire plug behind USDS dash speaker - Headlight washer
3. Plug/hose next to rear "subwoofer" - Washer motor for ambulance doors
4. Plug underneath body - Aux. fuel transfer pump (93-97)
There are more, I know it... I'm going to try to find them all.
If you do not have it, who cares? My wife's 4WD Toyo van comes with stock connections for rear axle locker, refridge, ice-maker, and other things. She has rear AC, Rear Heat, Front lock. If the things are not installed, what does it matter what the plugs are for? If you want to install the things, go for it!
I think its also an option for the LX. Its an option model that Ejects bad Dates or unpleasent Wifes out through the Moonroof from the passenger seat. Or it could just be the connection for the Amp and center subwoofer???
There is one on the drivers side inside of the plastic panels near the jack...
JO MAOMA,
You've got a PM..
DougM
