its an Idea bir problem?
Alabama
Website
www.auburn.edu
after reading this I thought?
"When you brake a birfield don't just wheel home on it. Not only are you chewing up the insides of your knuckle every time you steer but there are times when you literally can't steer in one direction or the other which can be very dangerous on the road. Even if you take off your front drive shaft and take off your hub covers your still gonna do damage by turning those wheels back and forth. You have all sorts of sharp metal in there plus the balls all getting in the way and binding up the knuckle. "
what if you take the birfeld out so you remove all the junk. the put you knuckel back on. with it work just to get you home?
