Issue after oil change.....
North GA
1992 3FE....changed oil and used D3 small filter (8qts). Also cleaned throttle body and tightened clamps.
Now I get halfway down the road and the engine starts to smoke....almost like its overheating. But no indication other than the smoke coming from mid to rear engine area. First time down the road it also took off like the throttle was stuck!. Pulled over and checked the throttle and it seemed fine.
A brittle vacuum hose did pop off while I was cleaning the TB. I pushed it back on after the throttle issue. Drove it back home and light smoke again from the engine.
Any ideas??? Thx
Idles fine, no issues. Giving it gas, the RPM's hang up slightly longer than they should. Letting off gas the needle should drop quickly, but now it seems a tad slow to do so. And that's when the smoke starts.....after you start revving it up. Grrrrr.
TPS maybe? I thought maybe that small D3 filter.....damn thing doesn't even cover the entire surface area of the filter seat.
Any 3FE brothers wanna chime in? Gotta figure this out before work tomorrow :cheers:
I'm leaning torwards throttle position sensor. But would that make the engine heat up to the point of smoking?
How long have you had it running? How did you clean the TB? (TB or carb cleaner?) Mine always smoked when I did that with the TB still attached. From what it sounds like, you didn't do anything to cause any problems. If you used a lot of cleaner, it sometimes takes a little while to burn off.
Apparently I grabbed mass air flow sensor cleaner. I squirted some in the actual throttle body with the chamber closed, just to clean out the gunk on the outer chamber. Wiped it down and reattached the black hose portion and clamped everything down.
So you think it's just burning off the residual?? That might make sense. Could explain for the sudden outburst and surge in throttle when I first started driving it! I had to cut the truck off to get it to stop. After that, no more surge. But the smoke continued to be there once I started throttling up.
I used to work as a delivery driver many years ago and me and the manager would sea foam some of the trucks and wouldn't tell the drivers that we did and we would get calls of the trucks smoking lmao it was just burning off the residual in the intake. That sounds like what your rig is doing to me
Drove it around a bit this morning without issues.....still burning off residue and smoking some. No dash lights or temp change etc. I must have sprayed a lot more than I thought in there :doh:
Thanks
