isolator, or selonoid???
utah
i used to run an isolator for my dual batteries. the isolator went out, and took my alternator, and tach with it.. have heard that cont. dutie selonoids work well. can anyone tell me how they work, and the best way to wire them. all i run off my 2nd battery is my 2 winch's.. thanks, and god bless:beer:
Neither.
Not worth all the screwing around.
Wire both batteries up in parallel and be mindful about how you use the electrical system. Has worked fine for me since 1995.
Good luck!
-Steve
Use your head about how long you are operating anything electrical with the engine not running or running. Realize that using the winch continuously for a half-hour may drain your batteries.....:doh:
:beer:
enj0ii said:
p.s. the only wire connecting the 2 right now, is the charging wire off my alt. a local alt./starter joint said that woukd be skippy till i ran a winch off the one. they said to jump the 2 together when i did that.. seems like a pain
That is why you need to hook both batteries together, (both positives to positives and negatives to negatives) with some quality double 00 welding cable.
