Is your Auto Tranny shift backlit?
Dumb little question but the indicators next to the auto tranny shift stick are not backlit on my 80. They are on the dash however. Should they be backlit? and if so is it easy to get to the bulb to replace it?
Cheers
yes it should be backlit. To change bulb remove front console- 4 screws, you will have to shift the stick lower to remover the console from around the shifter. then remove the 4 screws that hold the shift cover plate on. you will see a couple wires that run into it on the underside.. The bulb screws out with about a 1/2 turn. There is a green condom on it. im not sure if the new bulb comes with one or not. takes about 5 min.
Mine went out on New Years Day. So far, I'm just living with it.:meh:
It was blown on mine when I purchased it, later the D on the dash also went out.
I actually kinda like not having them. If nothing is lit up on the dash it means im in drive. haha
Not sure about an OEM bulb but a quick run to Checker netted me a new bulb and I carefully removed the condom off the old and put it on the new...
