- Joined
- Mar 27, 2003
- Threads
- 20
- Messages
- 619
E -
The T4/T5 connectors are a male/female combination that plug together. The two wires that pass thru are RH directional, and LH directional. This is where the commercial trailer harnesses pick up the signal for the directionals.
The commercial harnesses presume that your trailer uses a single filament/bulb in each corner for stop light/directional light (apart from the filament/bulb for the tail light). Since the Land Cruiser uses a separate bulb - and separate signal - for stop light and directional, the two have to be "blended" together (for lack of a better word...) into a single signal to run aft to the trailer lights without frying the works. That is the purpose of the converter.
The only case where you wouldn't need a converter is if your trailer had three separate bulbs/filaments on each side, one each for tail light, directional, and stop light. Then, of course, the standard harnesses would not work quite right...
Cheers, R -
Cheers, R -
