Is this strong enough?
Just built a new bumper. thought I'd post it up if anyone was looking for ideas. I have it attached with two 1/2" bolts through the frame on each side as you can see. It has worked OK in the little I have used it, but do you think it will hold up for the long run? Also if you have better/stronger mounting ideas any advice would be nice. thankyou. The structure inside the bumper is hard to see, but it is heavily braced inside. the front is 1/4" plate and there are two 3"x1/4" pieces of flatbar welded @90* to the front plate.
I would make sure you are using at least grade 8 hardware and then forget about it, looks plenty good... assuming your welds are all in good shape which they seem to look.
Nice looking bumper. I like it.
REZARF <><
thanks for the replies, It sounds like it's good to go. I had the same winch on a mini and had it tied to the frame better with an additional crossmember, but I guess it must have been a little overkill. I was somewhat limited by the powersteering as to where to put the mounts. I have yet to see a winch break off, but if it did it would do some serious damage. I am most worried about the strength of the frame it's self as it is the thinnest metal and would be most likely to tear, but I don't think it will.
Exactly how many bolts hold it to the frame, and what are their diameters? Also, what grade? Use grade 8, due to the 91,000 lb shear stress rating per square inch. Two grade 8 1/2" bolts would give you a shear stress tolerance of 35,000+ lbs. You'd be ok there then, but always add backups! Grade 5 is 71,000 lbs, and would be around 30,000 lbs. More than 2 bolts is a good idea, and from the looks of things you've built a solid bumper!!
