Is this Normal Sounding? (Video)
Tempe, Arizona
This truck is pissing me off as of late. It still shakes at idle in drive and has issues when cold. I just got my first actual MIL for a misfire today - #4. I just went and pulled the wires off the plugs one by one and the idle changed each time.
This is a video of how the thing sounds at idle:
YouTube - 1FZFE
Ignore the huge exhaust leaks, they make it easier to tell how the engine is idling oddly.
I had an idle problem - turned out to be pcv hose and valve that fixed it...
We don't have EGR's on our 80 series in Australia - but they can cause an idle problem as well I believe.
Greetings,
Sounds like belt noise to me. When was the last time they were changed?
Steve
94' 185,000
I have the usual P401 EGR insufficient etc. New PCV installed and I'll be replacing every vacuum line tomorrow.
Easy stuff first
have you checked the bottom of the corrugated portion of the rubber intke hose for cracks right above the valve cover? very common.
another is cleaning the throttle body and adjusting the TPS,
Your exhaust leak can also cause truck to run rough as the o2's will be reading bad data, on the front of the exhaust pulse exhaust gasses leak out but after the pulse travels by the vacuum draws in air,
you have a bad pulley bearing,
The less easy,
The misfire code is a classic symptom of a damaged harness near the EGR pipe, the heat softens the wire insulation and the copper pulls though and they randomly short to each other,
Also do the bubble test, open the radiator overflow but leave the tube in the coolant, watch wile you rev it to 3K rpm look for bubbles, onless the system has been opened recently there should be none.
The rubber intake hose is fine.
The TB is cleaned, I've yet to adjust the TPS though.
The exhaust leak should not cause the truck to be weird when cold - cars do not pull data from the O2 sensors until it is in closed loop.
Interesting on the bad pulley bearing - it started after my new crap brand belts wore in. I'll check it out.
I was thinking about the wires around the EGR pipe. I'd poked, prodded, and moved that whole package around while the truck was idling and it didn't cause anything to happen. I really need to open it up and check it out.
The bubble test is negative. :)
Thank you.
ahh, are they cogged belts? (little teeth on the inside sirface of the belt) then that may be just the belts, try Toyota belts,
Belts get noisy often because they sit too far into the pulley "V" ... the noise is frequently caused by the belt being pulled out of the "V" as it travels to the next pulley. Try pouring a little warm water on the pulleys while engine running (watch your fingers) ... if the squeal disappears thats your culprit... replace the belts asap with OEM.
Not sure about the O2 "closed loop" stuff... but before God made engines with anything other than points, a coil, and plugs....a leaky exhaust would/could cause rough idling ..
