Is this an option??
midwest (iowa)
Im nearing completion on my 1971 resto. I have used a donor 1973 fj40. Ive used a number of parts from the donor, most importantly the wire harness. It's gone well.... with only a few modifications necessary to marry the 73 harness to the 71. I did run into a hiccup with the blinker switch connecting to the wire harness.
So here is what I have...
The wire harness has a plug designated for the blinker switch with
2 green/ with yellow stripe
2 green/ black stripe
1 green/red stripe
and 1 green/ blue stripe
The blinker swith (Pigtail) has 6 wires Not in a plug thanks to the PO (six loose wires)
2 green/orange stripe
2 green/yellow stripe
1 green/white stripe and
1 green/blue stripe
My question is... Can I magically hook these six wires to those six wires and have blinkers, brake lights? I have the rear wire harness in along with new rear and front blinkers connected into the harness. Its just down to this group of wires under the dash. .. I appreciate any help you can dish out.
fsm with a factory diagram worked for me because it seems like the colors change every few years
factory service manual..they have diagrams for all the years probably find them on here for free
Good luck, I tried to replace my turn signal switch and wiring and gave up and installed an aftermarket switch. I bought a wiring diagram and I could never get it correct. I saved my parts to maybe try again someday so good luck with yours.
