Is this a good deal?
North Little Rock, AR
I might be able to get a used, don't know the build date but from the pics it looks slightly used, m12000 for $700 bucks. Would you pull the trigger?
That's about what I paid for my used 9.5XP. I think it is a good price. The motors can be rebuilt or replaced and the gear train has a lifetime warranty. That winch should last you a very long time.
Well I just got the guy down to $600. I'm going to make sure it works when I pick it up but is there anything else I should be looking for. This is my first winch so I want to make sure I know what to look for to make sure I'm not getting screwed.
Thx
Here are some things that you can look at to give it quick visual check and run through.
- spools in under power
- spools out under power
- free spools out
- give the controller a visual check for damage, loose pieces, etc
- check the controller cable and plug for damage
- check the cable for kinks, burrs, broken strands, crushed spots, basically any damage
- Check the hook and connector link or other form of attaching the hook to the cable for visual damage
- is the hook gate still present (they often are not)
- is the gate bent?
- any visual damage to the winch itself? Check the four mounting feet - both where they directly bolt/mount to a bumper or other mounting surface, and also the body of the winch itself for cracks.
If it checks out well enough then I'd go for it. You might want to go ahead and count on pulling the gears out, cleaning out the old grease and adding new. If you aren't in a hurry you could pull the gears on site to see if they are rusted from water intrusion.
Good luck!
