- Joined
- Sep 16, 2008
- Threads
- 25
- Messages
- 143
Hello,
Question: changing stock 96 fzj 80 r/p to 5.29 not changing tires, yet(yes i know it will run 4000 rpm at 75mph, don't care) what i do care about is is this going to screw with the transmission shifting? I understand that rpm will increase, inversely actual speed will decrease. However im not sure how the transmission (ie stupid computer) will be effected by the new descrepency between higher rpm and display speed on speedo and actual slower mph.
will it still shift at the correct rpm or will it hold out until i get up to a certain speed. Or exactly what will happen by not recalibrating the speedo. Will there be any codes.
I realize the speedo will be incorrect vs actual speed, but will the car go from Point A (zero MPH) to point B (65mph) and run through all the gears like it is supposed to. Also say i am not accelerating , but traveling at a constant speed say uncorrected speedo speed 40mph/ actual speed 20mph (bare with me this is a rough approximation) will the tranny want to shift into 4th (overdrive) since the uncorrected speedo is 40 or would it be in 2nd since the actual speed is 20mph
Thankyou for your responces.
P
Thankyou for your responces.P
