one end turns (next to where the steering stabilizer is connected, left side), the right side no turney. Should it?
smokethedog said:I did notice grease coming out of the rubber boot on the right side when I torqued down on it trying to get it to turn... Didnt see that it was torn any, I think it just pulled up out of its seat.
semlin said:the next step is heat for about 5 minutes. the step after that is threading a 21mm deep socket over the other end of the 17mm wrench and then attaching the longest extension bar you can to the socket for a lot of leverage. the step after that is popping the rod ends off the steering arms and putting the whole rod in a good vice and repeating the heat and extension trick. that was what finally worked for me. I would invest in some antiseize if you get that far.
RavenTai said:One thing I don’t like about the FSM is it is full of how's but very light on why's, the 96 LX NCF fills in some of those but not all. Were there any match marks on the steering column?
smokethedog said:tried that. the damn thing wouldnt budge. sprayed wd40 on the threads, still wouldnt budge. Any other miracle snake oil out there that will help break this loose?
Need to find something to use for removing my front O2 sensor. The nuts are rusted crazy.
advice?
job IMHO.
