Irratic interior lights
Chugiak, Alaska
When I bought my 1993 FZJ80 the interior lights would not come on when the doors were opened and would not turn on with the switch. Today they had decided to work intermittenly. Would a bad door switch do this or do I need to trace the wiring back from the dome light? I assume the map, dome and cargo lights have the same power source.
I'd check the door switches, first. My 1993 had similar issues, when I bought it. I tried rebuilding the switches, fixed some of the problem, some of the time. When I replaced all four switches, I fixed it permanently. I really doubt it's your wiring, unless you've had some mice or something else chewing on the insulation.
If I hold the switches in just the right posision(usually pushed towards the ground) they work, at first I thought it was the bulb, But I know now its the switch, But I wont go into the second door light not working when the first door light does...
I have a 94 and 3 out of the 4 door switches were fried. Drivers side and the 2 rear doors needed to be replaced. Toyota had all the switches for $20 each. Simple install, and now my inside lights do not illuminate at night when I make left hand turns!
