Ironman front Bumper fog lights??
California
I have an Ironman front bumper for my 100 Series and the fog lights it came with are s***. I know they sell upgraded LED ones that are brighter, but I was looking to go with ambers. Anyone have any experience installing Baja's or some other amber fog light in their Ironman front bumper?
Following. Agreed about the standard Ironman lights being terrible. The LED Ironman ones were more of a cosmetic upgrade than functional unfortunately, but they are definitely better than the ones that come with the bumper. Would also love to know if someone else got an aftermarket bulb/light in the fog light spot.
I also upgraded my Ironman fogs to the LED version. Better but not a drastic change.
To the OP i assume you can buy some laminx film and make the fogs amber yourself. Shouldn’t be hard to do.
Thought I was the only one that thought they were complete *$$. Changing the bulb is especially a chore.
Baja Squadron Rs are for 4 inch openings. If the Ironman is that size, I can't imagine they'd be hard to install. Might have to make some sort of bracket.
OP, can you pull on off of your 4runna to test?
Upgraded fogs are on. Some modification was needed but it was straightforward.
The fog wells were formed to the OEM Ironman light housings and the mounting bracket sits about a 1/2" back. The stock Diode mounting brackets were too wide to fit through the gap so I cut two slits into the steel housing and plastic cover. Snapped off the plastic and bent back the steel to make room for the stock Diode bracket. The install was simple from then on out, there are two bolt holes to use on the bumper fog bracket. I used the stock diode bolt on the right hand side hole, which did need some rouding out with a step bit, and wired to factory fogs.
I probably need to go back and add some rust proofing to my cuts and bends on the bumper but not sure where to start there (taking recs pls).
If anyone is interested the Australian company Stedi makes LED driving lights that are a replacement for the Ironman fog lights.
NOTE: These are only available on the Stedi Australia website so you need a VPN to get there otherwise it will re direct to the USA Stedi site and they are not on there. I have bought multiple things from Stedi in Australia and shipping is about 1 week generally.
I have their lights on my ARB bumper and they are brighter than the headlights on my 100. I havent used the ones for the Ironman bumper but assume they are similar.
Stedi fogs in my ARB Bumper
View attachment 4067305View attachment 4067306View attachment 4067307
Got a P/N?
