Ipf x91 9006 upgrade bulb
South west utah
I purchased the slee wiring harness along with a set of the ipf x91 9006 super low beam bulbs to update the lights on my 91. I got everything installed smoothly but the new bulbs keep falling out of the headlight assembly. Like they are not locking in correctly. What am I missing? was I supposed to file a tab on the bulb? Any help would be appreciated. Thanks
Should be pretty easy to lean over the radiator support and look at what the bulb is doing and whether or not its seating correctly. Go to whichever side doesn't have your battery as that will be easiest to see.
Seeing isn't the problem, I have the headlight housings removed and these bulbs fit in the low beam socket, but they won't stay locked in the housing and they fall out after a day or two. The bulb goes into the socket just like the oem bulb, it just doesn't stay twisted/locked down.
Have you done a side by side comparison of the old bulb and the new to see how the tab sizes compare ?
Yeah, two of the tabs are the same and one is smaller than the original. I measured the two and the ipf has a slightly smaller diameter. I think that is why it is loose. No way it fits tight enough to keep water and dust out (could be the reason people claim these bulbs burn out quick) I just put the original ones back and I will try another brand of bulb.
