IPF Bulbs and Replacement Headlights!
Greenville, SC
Hello,
A few months ago, I bought one set of the 110/80 watt H4 IPF Bulbs. Part number is HHC1211080. Reason for this thread is, I was under the assumption that they plugged right into the back of the stock headlights, but they are HUGE :eek:
Now for the questions:
1.) Where are the IPF replacement headlight inserts for the 80's for purchase?
2.) Did I buy replacement bulbs for headlights or mounted style lights?
3.) I want to use these, so what do I need to do?
Thanks in advance guys, and I DO have a Slee Harness installed!
-Josh :cheers:
The headlights are 9005 and 9006 bulbs for the high and low beams. The H4 are replacement bulbs for aftermarket bolt on lights and are incompatible with the 80 headlight housings. Those numbers are the key designation factor on what will fit what like 1157 is a brake/turn light. You can buy higher wattage replacements but to fit the OEM housings you must get a set of 9005 and 9006 bulbs respectively. Do be cautious as it is possible to over heat the housings with bulbs that produce too much heat. Check here and you should find the info you need. Good luck.
IH8MUD™ Forums - Search Results
Thats weird! I had a feeling I bought some after market light upgrade bulbs. That's cool, because I can use them in the IPF 800x's I am buying. Well then, does IPF offer 9006 + 9005 replacement bulbs? If not, what else that is equal to that quality?
And for the record, I searched the forums, and there are not many IPF threads on the site.
Thanks again,
-Josh :cheers:
Are the FatBoy replacements on Slee's site, compatible on the 80's headlights?
Do a search for HIR bulbs. The best plug and play bulb for the 80 series headlamps.
IPF 9005 bulbs - Google Search
Ah, the power of Google. :flipoff2:
I have had good results with PIAA, IPF and Hella. IIRC they all makek 9005 and 9006 bulbs.
I know, I know ...
I'm being dingy! Thanks man, I was just looking through man-e-fre, Slee, Davesport, all those places I trust, and totally blew off my Apple home page, goooooooooogle ... :bang:
I think I got my questions answered on this one! :D
Again, Thank You!
-Josh :cheers:
