- Joined
- May 19, 2008
- Threads
- 1
- Messages
- 2
I have a question concerning how I can connect things to an inverter. I currently have a 400W Xantrex inverter that is converting DC battery power to AC to power some lights in a barn. Now, I also want to install a fan in the barn to provide cooling for animals. The problem: the fan does not have a plug coming form it - it just has a hot, neutral and ground wire. Since my inverter is not one that can be hardwired to accept individual leads (as above), my only alternative is to attach the hot, neutral, and ground leads from the fan to a electrical plug, then plug into the inverter. I could also strip the insulation from a three prong extension cord, and hardwire the leads from the fan to this, then plug the other end of the extension cord into the inverter.
Is any of this OK to do? While it certainly is not difficult to "jerryrig" a plug as described above, I'm not sure it's exactly legal by electrical code. Then again, I guess the "barn electrical police" aren't going to come around looking. However, I'm not sure there's a better way. I looked around for hard-wired inverters, and I can't find any, nor do they generally come in less than 1000 watts (which would be too much of a drain on my battery system).
Any suggestions?
Thanks,
arthuritis17
Any suggestions?
Thanks,
arthuritis17
