Hello IH8MUD community,
I have lingered on this forums for a while looking for information on various things for my FJ40. I have owned my 75 FJ40 since 1995. Rebuilt the engine, transmission, transfer case, and did a bunch of other things to get it on the road so I could drive it. Drove it for about 3 years as my daily driver then needed something more reliable and comfortable. Then life, work, family happened and it went into storage for about 20 years. Crazy, I know. Finally decided to get the old 40 out and get it running and back on the road.
Was going through and checking the oil, which was good and no water or coolant. Checked the radiator and the coolant was low. Interesting. Pulled the distributor to get oil flowing through the engine using a drill and oil was making its way up to the head and rocker arms. That's good. Pulled out the spark plugs and bore scope the cylinders and #6 did not look to good. Did a compression check and all cylinders were ok except #6. No compression. Found the exhaust valve was stuck open and would not close. Pulled the head and found this.
Since I had already rebuilt the motor before and had to bore it .030 over, I have no desire to do that again to .040. Just going to drop in a Chevy 5.3. Not before I fixed my frame rust/ rot issues. So a complete tear down was needed and completed. The frame has been sandblasted and it is amazing all the issues you find once the rust has been removed.
So my rebuild saga starts as most of you already know. This build will move along slowly, but it will keep moving. I need to start a build post as some of you may be able to answer questions I have as things progress.
Thanks for stopping by!
Jason
Jason
