Intro & superchargers
Skippy's Wonderland (OZ)
Howdy guys and gals,
Ive only joined up a few days ago and i cant believe how much info has been amassed for the mighty 80s here. Ive been missing out on heaps.
I found this site while searching for info on the TRD superchargers to suit my truck as no one in sydney/oz seems to know about them. Aftermarket kits are available though the impression I get is they are not the best in terms of fitting simplicity etc.
For those of you who have reasonably modded trucks know, by the time you lift it 6in and bolt on 35in tires the mighty power of the 4.5L petrol goes out the window. Ive swapped diff gears to 4:56s, fitted full exhaust and extractors plus a unichip and that satisfied me for about 2 weeks and now its time for real power applications.
After much searching through the many "supercharger" threads its clear im on the right track though identifing the correct model/part number/source of TRD supercharger has drawn a blank.
My main confusion is there seems to be 2 types - 1 for pre '95 80s and 1 for post '95 80s though I dont know why as im not aware of any block or cylinder head changes that affect the fittment of the SC/kit. I want to get this 100% right before I order it.
Since mine is a '96 80s 1FZ-FE ( RHD )I"d be most greatful if I could be pointed in the right direction.
PS: closest I got was on the SOR website but they are discontinued.
Thanks in advance for your help and once again hello to all.
Regards,
Nathan
Nathan--
First, welcome to MUD:flipoff2:
Hate to be the bearer of bad news but the supercharger has been discontinued from toyota, hence your dead end on the part #. I have heard a rumor of a reintroduction but well have to see. I dont know what the international parts pool has to offer you but there are other forced induction options, and several threads here on current builds.
cheers mate
Welcome, The supercharger is in redevelopment stages and there is intentions of reintroduction.
Also the pre 95 S/C is slightly different due to the location of the EGR setup IIRC, whereas the 95+ models have the setup on the backside of the block between block and firewall.
Hope that helps understand the difference in models.
The difference is that the 93-94's have the pair valve mounted in the way of where the S/C goes, so the 93-94 kit has parts to move and relo the pair valve assembly.
I'll bet a kit for a 95+ would work for any aussie rig, I really doubt they have that stoopid pair valve set up like mine. Moot point, though, if none are to be had. You might consider 5.29 gears, some here claim to really like them for 35" tires.
Hi
I am a newbie here, first post even...I drive a 93 gxl 1fz-fe powered cruiser. I am an Aussie.
In Australia, CAPA (www.capa.com.au) make a couple of supercharger kits for the 4.5. Intercooled (270kw) and non IC (240kw). Hope this is of use to you. Cost varies by kit but around 8k i think gets one.
I am more interested in turbocharging my 1fz-fe. Seems to be the best option for low rpm torque which suits me as i spend lots of time towing boats around. I have only just started looking for turbo stuff in this forum and this thread was near the top of the list.
If anyone has had experience with both turbo and supercharging i would be interested in any comparisons.
TB
:flipoff2:
As far as SC vrs. Turbo applications do a search it has been thoroughly kicked around and sometimes still is cause it seems we can't get enough of it.
