Intro and help
Oklahoma
All-
First and foremost, this is an amazing site and community!
After looking long and hard, I purchased a '96 LX450. I probably paid too much but it's triple locked and upon driving 90 or so miles to check it out, didnt see / hear anything I didn't think I couldnt tackle with the benefit of an FSM, some "me time", a few expletives in the privacy of my own garage and all without making hard decisions about kids in college or Dads hobby (read: no obvious rust / no welding).
Ive had it almost a month and drive it every couple of days and with some light wheeling and the list of "need to do's" has grown but nothing dramatic, until I discovered the attached. Upon replacing the front bumper (it was in the need to do as the OEM was trashed / bent) I discovered the rot on the front body mount / clip attached.
After throwing up in my mouth a little bit (thus, the primer spray), it looks like this is a bolt in front clip (no welding / major surgery) My googlefu has not produced particularly instructive results. Can anyone confirm / deny my cursory inspection and conclusion? Have experience replacing, do's/dont's? Have a recommendation on pulling in the junk yard vs aftermarket?
Thank you in advance for any and all suggestions/pointers.
P
Yes, it can be readily replaced.
Thanks, Pete. Any experience with pulling parts vs. aftermarket?
I believe this is called the ‘core support’; someone will chime in if I’m wrong....
My girlfriend rear ended someone a while back in my previous 80 and the core support was bent inwards. I found another on a donur truck that had been totaled. It’s quite a bit of labor to swap them out but nothing difficult. I think it was about an hour to strip everything connected to the core support off, lots of bolts and fasteners.
The reassembly was just as tedious but nothing difficult. Pure sweat equity !
Can't tell how deep that rust is, but it might be worth addressing now and checking on over time to see how it holds up before going thru a swap. I'm a fan of Eastwood's products (and others will weigh in as fans of other products), and if this is surface rust, just wire wheel it til all the flakes are off and the spot is kinda shiny. Then lay down some rust converter which turns black and is hard as a rock. Next put some rust encapsulator on it and finish with chassis black (matte or gloss), and you should be good to go. This all assumes that that rust isn't perforating the core support, in which case, you may want to go the swap route.
My 15 year old daughter picked up a 1976 Ford F150 SuperCab pickup this summer and we've been working underneath it to deal with the surface rust on the frame and suspension. The above procedure works pretty well - not perfect, nor show room quality, but good enough to stop/reverse 40 years of Seattle weather. It ends up a nice matte black finish. Will see how it holds up over a couple of rainy seasons.
Much appreciated advice. Unfortunately, the rot appears to be AT LEAST 1/8 deep. Ill add it to the need to do list and keep my eye out a clean core support.
