Since day 1 my 80’s speedo has had a mind of its own. Sometimes it work for weeks without any problem, and then all of a sudden it would stop for a while. At the time, I had too many other priorities on my PM list, plus, since it was intermittent, it didn’t bug me too much. Well, it went out again last week, and this time did not come back on. I replaced the VSS since it was full of oil from a leaking O-ring (yes, I replaced the O-ring too), but that only helped lighten my wallet and did not fix my problem. There are several posts on here that discuss either a non-functioning speedo or one that bounces all over the place on an intermittent basis. The cure may not always be replacing the VSS. The cure may be as simple as cleaning the ground…
1st pic shows the VSS ground circuit, 2nd is a close up of the ground point; next is a little wider shot.
Getting to this bolt is a little tricky if you have large hands. I found it is easiest to get to if you go under the master cylinder with your right hand and lower a 12mm wrench with your left.
Once everything was loose, I used some emery cloth to clean both the manifold and wire lug and cleaned up the bolt with my wire wheel. Put everything back together and now it works just fine. Hopefully this will help some of you who have experienced the same problem.
