Intermittent Sound Low Acceleration
Calgary
Website
www.speedracer.ca
Problem:
Just started to hear this after a cold blast week (-30-38C for a couple of days)
I can't replicate the noise and it only seems to happen once or twice while I am driving. For the past 2 days I haven't herd or felt any vibrations (Warmer day -15C --> -20 C)
On a deceleration and re acceleration (under 10mph up to 15mph) I will get a rubbing noise against something. It feels like something is not rotating correctly. If I maintain the speed or increase speed the noise goes. During this time there is a slight vibration as well.
I've gone underneath to look thinking it might be the brif but everything looks in order.
It could be a dry spindle from my extensive search and reading but I just did work on it before winter.
I'm thinking maybe ujoint ...
CDL - Ok no noise at any speed
Dif locks - OK no noise as I drive around a snow / gravel area
Any suggestions as to what to look?
It's too cold for me to do any work so I will be sending the truck out to a local mech if I find an issue - otherwise i'll just ignore it....
it wouldn't hurt to check out your wheel bearings - they can always use a repack and re-tighten to spec.
-Phil
When my spindle bushings apparently got dry I started to get a rough rumbly vibration under normal acceleration first drive in the morning, was not as cold as your temps, but much colder than normal for this rig. I put 1 1/2 tubes of 3% Moly fortified grease into each knuckle via the square plug/ports; noise went away immediately. In your temps, might be of benefit to use a synthetic Moly fortified grease like Valvoline's Synpower which is about 1-1 1/2% Moly. Also lube the driveshaft yolks with Moly grease. Mobil 1 synthetic (no Moly) for the four U-joints.
There was a discussion recently about the synthetic greases used on the driveshafts. Some people seem to think the dino's are the way to go because the synthetics are too hard or thick. Basically if I understand correctly the synthetics have a tendancy to gum up behind the zirk and prevent grease from penetrating.
Vibration
I am having the same problem. Loss of power and a vibration that is driving me nuts. I had the belts changed a month ago and found out that the mechanic ran the belts wrong so this guy bought new ones and ran them the right way. I am also having a down pipe issue where it is leaking right before the converter. Was wondering if the down pipe leaking could be causing the truck to act like this. All of these problems started when I put a 2 1/2 inch lift with 285/75/16 tires on this truck. Any suggestions please help.
