Intermittent grinding while driving
Philly
I am trying to diagnose this new grinding noise, kinda sounds like metal teeth grinding every once in a while. It just started when I took it off road for the first time, extremely mild sandy fire roads. Notable items are as follows:
  • Sounds like metal teeth grinding
  • Occurs for 1-3 seconds
  • Intervals of 10 seconds to 10 minutes apart
  • Happens while moving at any speed
  • Happens under load and when just coasting
  • Happens in any gear, low to neutral
  • Happens in 4 high or low
Recent work
  • Recently had front axle rebuilt by a reputable member on the forum, hes done a ton of em, 300 miles ago
  • Removed VC 300 miles ago, flushed transfer case
  • Recently flushed transmission 600 miles ago.
  • Just noticed inspection cover on torque converter missing...
I will get video soon. I have read about bushings on the axle get dry but since it was a recent service I don't know if it was this is the culprit. Can sand and gravel get into the torque convertor area and cause a grinding noise?
Check front drive flanges on front hubs.
