Intermittent Clicking Noise
Santa Monica, CA
SEE EDIT BELOW
Hi all - sorry if this topic has been solved already, I searched and I could not find an answer to my question.
About two weeks ago I started hearing an intermittent click coming from the front end at specific times: when I am pressing the gas pedal and accelerating from a stop, sometimes when I am maintaining speed from 1-10mph, sometimes when I am coasting forward and finally when I am coming to a stop.
The click fades at higher speeds. I know the sound a birfield makes when it is worn out and I do not believe that this is a birfield, but I absolutely might be wrong. I recently had the brake pads replaced by a new shop since I recently moved.
Two videos below, please note that I am in a parking garage so the sound is a little more pronounced but also might have a slight echo.
I checked the drive shafts, the brake pads, the dust shields, the tread on each of my tires etc. My working theory is that it is a worn out spring in the brakes or one of the brake clips, or worst case scenario a completely decimated birfield.
Edit for anyone googling this issue: it turned out to be my left front wheel bearing. Replaced in a couple hours for cheap, it hadn't damaged the hub.
Was the noise there before the brake job?? If not, probably related to the brakes.
It was not. I got the brakes done on January 29th, I had no noises until two weeks ago. In the past two months the only thing I have done with the truck other than drive it to and from work (2 miles) was a trip to Death Valley, which was also about two weeks ago.
You could try jacking the front end and spinning the tires to see if you can hear the noise. I would look at the brakes first before anything else.
Did they use new shims for the brakes? Maybe the pad is moving around.. also check the caliper is tight
First vote is for brakes. Sounds like one might be hanging up.
Second is for drive flanges
Third is for U-Joints on driveshaft
Fourth is for wheel bearings
If the shop touched ANY one of these during their service, I would look at those items FIRST.
If you've never done your wheel bearings, then I would move that up in the priority list.
