intermitten start
I am the new owner of a 1997 LC with ~150K. This looks like a knowledgeable place to turn so here I go . . . .
Seems to be in pretty good shape with a few hiccups. There is an oil leak on the intake side but I have not really gotten under there to take a look yet.
The real problem right now is the intermittent no start. Turn the key all the lights come on but the starter never turns or clicks. I tried the "whack the stater with a hammer trick" to no avail. I searched the forum and did not find anything that might help. I also was going through some old repair records and it looks like the starter motor was replaced about 10K ago. When it does turn over, it starts immediately. Also appears to be a new battery.
I am thinking this is some kind of electrical problem (ugh). When it does start, occasionally the key will be turned to the start position and nothing will happen for about a half a second and then it starts right up.
Another oddity is there seems to be a cable that goes nowhere. It is a beefy battery cable and it is bundled with the other battery cables on the positive side but it goes to nowhere!
Any thoughts?
Are your battery cables tight and clean, that extra one could have been to power an amp for an old sub system, winch, etc.. That cable could be if not terminated properly shorting out. Ditch it if it doesn't go to anything.
mine's doing the same and i suspect its an electrical problem. alternator? might have to get down there and take a look
When your rig wont start, verify that the CEL is on. If it is not on when the key is turned all the way prior to starting it will not start. This is related to the EFI Main breaker.
If this is your scenario, with the key in the off position, open the hood open the fuse box on the DS and pull out the round/silver EFI Main breaker, knock it slightly on something hard, replace and check for your CEL prior to starting again. If it lights up it should start. Report back with your results. HTH.
Link here: https://forum.ih8mud.com/80-series-tech/169672-forum-newbie-92-fj80-hot-weather-mean-no-start.html
