Intermintent no start
Kansas
The wife let me know that her car wouldn't start the other day, did the same thing today to her, then to me. When the key is turned to ON all the lights come up as they should, when turned the rest of the way to START there is a click (one click only) that sounds like it comes from the starter, the voltage meter will dip but the truck won't turn over. All the lights will remain on, no rapid clicking like a dead battery, the only thing that changes is the dip from the voltage meter, telling me voltage is being applied somewhere. This can happen anywhere from 3-10 or more times before it will finally turn over and start up. It seems to make no difference moving the gear selector back and forth between N and P. Any ideas ?
Edit: I forgot to mention, I threw the volt meter onto the battery and got better than 12v from just sitting. With the vehicle running I was getting over 14v at the battery so I don't think I'm having a charging issue.
I had this happen to me on my Tundra before I sold it. Rob and I replaced the starter and it didn't have any more issues. @kc_chevota will be able to explain the "why" behind it (also, thanks for your help on that one!)
How old is the starter?
cant say for sure starter is the issue....but
starter repair is fairly easy - plunger - contacts - etc... kit is around $50.00
here a quick replacment amazon prime...
Amazon.com: Denso 280-0169 Remanufactured Starter: Automotive
the enitre starter itself comes out with just two bolts -
pull it out - give it a test (youtube starter bench test) - and check the copper contact - they might be warn down -
hell - with amazon prime you can do the old "test and switch" if you still have the problem with the "new" starter -
sent it back.... :cheers:
bF
the one click usually indicates that the contacts on the solenoid part of the starter are worn
they make kits to just replace the contacts for probably around $20
not to hard to do either
This sounds like the issue to me as well. Parts from @beno, @cruiserdan, etc... are cheap and easy to replace. You will need to know the part number on the sticker on your starter to order the correct parts.
Starter. I replaced my OEM starter with a Duralast starter. $90. They are lifetime warranty. I put the old starter on the shelf with the plans to rebuild it one day for a spare.
I should have put in my original post that I rebuilt the starter with OEM kit back in 2014. I went back out earlier and checked wiring from the starter back. The two cables on the housing were tight. Got up to the battery and found a nut that was about a thread and a half loose. Its the one that holds the three little connectors onto the + battery terminal. I do not know what those three connectors do, but hopefully that was all that was causing it.
Well, I'm pretty sure one of those is your main power...
I had this issue in the past (twice) the first incident at 120k miles or so it was in fact the starter solenoid contacts so I replaced the starter with a new starter this solve he issue. The second incident at about 150k I had intermittent starts this time I replace the starter under warranty and it seem to be ok for a few days and again the same issue. Click no start I replaced my battery thinking it was on its way out after 4 years. The frequency of the failures reduce but still had an issue. Ultimately after reading many post here I found some of the guys had issues with a relay that is in the starter circuit, I guess over time it stops transmitting enough to current to the starter motor. My solution was to wire in a solenoid that was controlled by the feed to the starter. After this I never had an issue now at 170k.
@98 SNAKE EATER has a different setup. Wires a push button or something...
