interior rattles/squeaks
I get wind noise from the front windows unless I stop them JUST before they are all the way up. Have them down just a little without any gap and dead silence. Sweet beautiful silence.
concretejungle said:
I"ve got the moonroof/sunroof (which ever you prefer) rattle also. Very annoying. I've looked in the FSM as to how to adjust but it looks kinda complicated actually. Not sure i know what i'm doing up there. Plus i'm worried that all the plastic parts have been baked by the sun for so long that as soon as i start fiddling with it i'll start breaking stuff.
I had a creaking sound in the way back that took me 2 weeks of
telling everyone to be quiet (3rd row up against the windows :D)
I have the moonroof one as well. If I press upward on it it stops.
It really is just a faint creak when going over bumps. I'm going to
try lubing the tracks and such this weekend.
i just fixed two big ones. Very timely post for me. One of the tailight guards that the PO installed was hitting the lower part of the tailgate on bad bumps. Got rid of the guards - no more noise.
Also had a bad rattle under the dash. Ftraced it to one of the many black boxes under the dash being loose. Installed some foam rubber - all set. Ah...
There is a common rattle in the roof above the drivers head that some may be mistaking for a sun/moon roof rattle,
It is a wiring harness rubbing, one member here documented it in a past thread.
Mine went away for a wile after I installed the driver grab handle but it has since come back
My console vibrates at idle sometimes and bothers me slightly moving the console usually makes it go away.
But after driving my 62 for two weeks getting back into the 80 is like stepping out of a gravel truck and into a recording booth.
The 80 is also better in just about every other possible measure except for purchase price.
I am impressed at the rock solid build. No rattles or squeaks and it seals up like tupperware- the doors still have that airtight seal quality -if you know what I mean. I am really, really impressed by the 80.
I notice the front seatbacks "rattle" on washboard. They aren't loose but i dunno. I dont consider it an issue.
It is a quiet vehicle but Toyota has upped the ante on vault-like silence in the GX. 80 is just avg at this point. I think a Dynamat parade would level the playing field tho :beer:
When I installed my stereo I used Dynamat on all 4 doors. Then last week I did the rear....floor, quarter panels, wheel wells and rear gate. Just amazing, the rear ringing and road noise gone! Well almost. Like 80% reduction.
Darwood said:
Right now I'm getting a popping noise that's comming from the front. It sounds like it's in the middle of the dash against the firewall. The thing is driving me insane. It only seems to happen when the truck bounces or there is a weight transfer like when making a hard left or hitting the gutter before going up the driveway.
So I finally figured out what the popping noise was. It turned out to be some loose body to fender bolts. As a last resort I found all the fender bolts I could find and tightened them. Some of them were fairly loose. I'm guessing they got this way from not being tightened properly at whatever body shop the truck was at before I bought it and from the wash boards in Death Valley.
It's amazing how crappy a truck can fell when it's popping. Now it feels nice and solid! :)
I took out my 3 row seats since I did not use them and they always rattled when hung in the rear:beer:
raer door rattle
My rear liftgate, 93 FZJ80, makes a ton of noise I tried adjusting the latch but it still didn't fix it.
Any bump and I get a big clunk from the back.
I'm tempted to make some rubber shims but would rather fix it properly if not too spendy.
Thanks
Holy thread revival, Batman!!
I have an annoying sound from my brake pedal. there is a little (<0.045") play between the clevis pin and yoke that attach to the brake pedal. I had Dan look into getting me the parts. I may just use some brass shim stock.
Dave
BRING OUT YER' DEAD!
I searched but didn't find what I was looking for. This looked like a good thread to revive and tag on to.
Rattle in DS door when window is all the way up OR down. Rattle is inside door near the left knee. It's really loud. Anyone suffering from this? Solutions? This isn't the same as the common ''window rattles unless all the way open or closed''. This rattles ALL the time. Ideas? I'd dive in but I'm the type to break clips and stuff and will end up buying a whole new door without a little advice and guidance.
Taking your panel off is pretty easy (I found out last winter after my window froze and the glass came off the rail)
take off the arm rest and latch
take your time and pop the clips one by one with a big srew driver under the panel.......then you lift the panel abit and vwalla.
i have an annoying rattle above the driver side. i think that it is a rib in the headliner? i recall a post a while back where someone fixed it, but i couldn't find it again. anyone have a lead on that one? if not, i can live with the volume knob fix.
cheers.
Thanks
If you pull the panel off there is a bar that should be wrapped in foam ther foam may be warn away. That fixed the noise in mine a couple of years ago.
cheers.
There is wiring with connector that can rattle wrapping with foam helps.
Nice thread. I have the most god awful annoying rattle. It is not loud but it is pretty close to constant. It comes from just below the passenger a/c vent and to the right of the glove box. I haven't had time to look at it too closely. Looks like a speaker. Usually if I whack it a couple times it will stop for awhile. I have a '92 FJ80 w/ 179k miles on it. Any experience solving this one?
Add small piece of foam with adhesive one side at existing door stop to tigten the doors when close
Mine only body rattles / vibration on
Pot hole and dirt roads
I added firm foam on door bumpers with adhesive on one side
Plus added thin foam shim around windows channels
