Interior project suggestions?
Fort Apache: Victoria
So if the weather is decent this weekend, I'm pulling the seats and carpet to continue my sound deadening project.
BTW, I'm using this:
http://www.b-quiet.com/extreme.html
covered with this:
http://www.proformproducts.com/en/products/detail/?id=60
I'm doing the floor, the transmission hump, and the rear doors. I have a huge drawer system in the back which is a huge PITA to remove, and since it already absorbs much of the sound back there, I'm leaving it put. If I have left-over stuff, I'll go as far up the firewall as I can reach, and maybe to the rear wheel-humps.
While I have the carpeting out, I'm going to
a) re-route the wiring to the sub and amp (sub is in the cargo area, and the amp is under the driver seat)
b) install my CB so the antenna cable and power lead are run under the carpet
c) clean the heck out of everything.
d) run the carpeting through the washer/dryer while it's out.
e) maybe run some big 12v wire to the back for a future project.
What else should I do while the interior is basically empty? Any PM you can suggest?
How old is your fuel pump?
Not sure what the average life span is, but changing it with the interior gutted could not get any easier.
Well, I didn't change the fuel pump, but I cut a small flap in the carpet so I can easily access it when I need to.
All in all it took about 7 hours from removing the first bolt to completion. Easy, but time consuming and not something I want to re-do.
I didn't wash the carpeting; a good vacuuming when it was laid out flat is all that was needed.
I routed the CB antenna cable in the lip under the doorways, and up over the rear wheel-well. It's invisible until it exits the tailgate.
Plus I found about $15.00 in change! Most of it was US currency, so I assume it was from the PO. There were 2 twoonies under the rear heater, too!
I meant to take step-by-step photos, but I sorta forgot. Here's one from right after I removed the stock carpeting.:
Spils of various stuff (thanks to the PO) caused some of the cotton underpadding to stick to the body (mostly on the RH footwells), as you can see. A small sunroof leak at the right rear corner might have something to do with that, too. It was a PITA to remove, as it tore4 off in tiny chunks.
But then, after a moment of genius, using a pet-hair brush like this really saved tons of time:
So whats the verdict on the sound proofing ?
Does it work ?
Was it worth it ?
How much did you use ?
How much does the tin weigh ?
Cheers.
Was it worth it?
Well, yes, it works. There is a slight reduction in the amount of ambient noise leaking in from outside. I can't tell for sure, because the roads have been rain-slick since I did this, increasing the outside noise. The biggest noise issue is the road-noise made by my 295/75 M/T tires. It has been reduced slightly.
There's definitely an improvement in tonal quality inside the truck. I had to turn-down the gain on the sub-amp, actually, as the added insulation made the bass too much of a presence.
There's a distinct change in the sound of the doors closing. If you've ever been inside an S-Class Mercedes or a car like that, that's the kind of "solid" door-closing I'm talking about.
I used approximately 43 sq/ft of B-Quiet Extreme, which weighs about 30lbs. 43' covered the floor from just behind the second row seats to about half-way up the firewall, and "doubling-up" on the foot-well floor areas, over the transmission hump, etc. The only areas which area single leyer are the edges and the spaces right under the rear seats. I didn't remove the rear heater and coat the space underneath it, because I'm not sure reducing the space around the heater is a good idea.
I also added two sheets of 29" x 32" Proform sound deadening material, which is basically non-flammable asphalt with an adhesive backing. That went in each foot-well, front and rear. That's about another 15lbs or so.
I had already done the front doors with some stuff similar to the B-Quiet. I think with the 7 sq/ft I have left over, I may do the rear doors as well. I think doing the rear wheel arches would help a lot; I just can't decide if I want to go to all the trouble of stripping and doing the cargo area. I bought two boxes of the stuff, so I have an unopened box still. I may dip into that a little and sell the remainder locally.
Was all the work I did worth the minute decrease in noise? No, not really. But I addressed a few other issues (had to repair a front seat runner, needed to re-route some wiring, etc), so it was a good "side-project" to do at the same time. Plus, as I stated earlier, there was a king's ransom in loose change just waiting to be harvested.
