Interesting dash lamp/electrical issue
Houston Tx
So while driving this weekend, I had an electrical ghost hit me while on the highway. The A/T temp, low engine oil, brake and voltage lamp all came on at the same time. This did not affect the engine or stall the truck. It ran normally but the voltage meter was a bit lower than normal. I have never sen this happen before.
I pulled over and before I could stop the truck, all was gone and back to normal. Stayed on for about 10 seconds. This happened again about ten minutes later, then last time while on the way back home from my destination. It never has happened again.
What I noticed was this: If one was to put the key into the ignition and turn the key to the run position, the warning lamps come on. After this "keying" the ABS and one other light(cannot recall at the moment, turn of(self calibration). The rest stay on until the engine begins to run. Well the lights that stay on before the engine begins to run are the SAME lights that came on while I was driving the truck down the highway.
Has anyone ever seen this or heard of this before? I will mention that I check the battery terminals and all were good. Beginning to think that maybe one of the wire terminals on the positive(+) post may be bad i.e. the grey male female connector. Also checked the plug at the alternator. As mentiioned, I have have driven it since (200+ miles) and have not seen it again).
Funny you mention that, just the other day I was driving and I seen those lights (not sure if they were the same) light up briefly, they went out and came on then off again but again just briefly. They were so dim and went so fast in and out I thought it was a short or something but I have not seen it since.
Tony
Your alternator is going bad. I have been getting the lights for about two years now, but only rarely. I have the new alternator ready to go, just going to do it at the same time as my water pump, maybe this weekend
Battery, alternator, wiring, or fusible links. Fix the problem ASAP, electrical surges or running low can damage many things including the ECU.
The battery and alternator can usually be tested on the vehicle for free from many auto places. Eliminate those two first.
I see....so a potentially bad alternator could cause all of the above mentioned lamps to become illuminated? I would think that just the low voltage lamp would come on?
I will get it checked out though. Just wanted a bit of feedback as to a possible common problem. Thanks
Does that same electrical issue apply if just the brake warning light is dimly lit? Just checked all the brake system today - fluid level OK, no leaks, emergency brake OK - but the brake warning light only is dimly lit. Was thinking that maybe something in the fluid reservoir cap unit was going bad. Thanks.
Sensor sounds like it may be bad.
