Interesting brake problem
Baton Rouge
About 4 months ago I installed an OME medium lift and did the LPSV adjustment of about 1/4 inch. Since then, I have noticed my brakes getting squishy. I often have to pump them to stop. Brake fluid is full and there are no leaks in the system. The symptoms suggest air in the lines or a bad MC from what I've read.
Today, I had to drive my boat and trailer all over town for repairs. Never once during towing did my brakes feel squishy, nor did I have to pump to brake.
Does the load of the tongue weight (appx 300 lbs.) or total trailer weight (3000 lbs.) affect the LPSV? if so, what adjustments can I make to get normal braking under normal non-towing conditions? Any other ideas?
Readjust your LPSV.
Ideally what you want is in a panic stop situation to lock up your rear brakes a second after you lock your front.
Disable your ABS (by locking your center, or pulling the fuse), then lock up your tires on a gravel/dirt road. See what locks up first. Readjust your LPSV until you get the behavior above.
