Intercooler Plumbing
Athol, MA
When building intercooler plumbing is it required to either buy connectors with a bead on the ends or have someone bead roll the connectors? I'm looking at only around 8 pounds of boost and wonder if the beading isn't important at those levels of boost. Finding a place here in MA to do the bead hasn't been easy.
I could buy my own bead roller, but at around $150.00 for a cheap one it isn't really cost effective.
I've run 2 systems w/o beading... on the street with a little adhesive things stayed together. Offroad did not agree with this method and things would slowly slide.
If you don't find a way to bead them, buy a section of tube that has an ID equal to the OD of the tubing you are using. Cut small width rings, bevel the edges slightly, and tack them in place on the tube ends. A few holes around the rings make great places to tack them and will require minimal grinding clean up after.
Parts of the Kazuma/TRD S/C do not have any beading (the elbows do, though probably not absolutely necessary), and I've never had a problem with them pulling off. At only 8 psi, I wouldn't worry about it.
my turbo set up sees 8lb boost often and I havent had a tube pull out yet and I have no bevels and am using cheap hose clamps and cheap silicone hose. kids on ricer forums run a lot more booste than that and use no bevels.
get her done
I agree. IME, the magic number for beads is 14 psi. Since the SC uses a bypass valve, there is no boost spike to drive off the hose. Spend your time making sure that there is enough flex in the hose to take engine torque over, a bigger problem with silicone hoses IMO, than doing beading at 8psi boost pressures.
Scott Justusson
94 FZJ 80 supercharged
