Integrated receiver
northern utah
A fellow mud member suggested I maybe do a build thread on an integrated 2" receiver I built last summer.. So just in case it helps anyone else, here you go.
First I picked up a 2"x 12" receiver stock and then T'd that to a cross member made from the same material. I used triple bead welds everywhere I could. Then I pulled off some paint around the four bolt holes on the rear bumper/ frame, slowly welded in material to fill them and then cut a 2" square over the top of them. Here's a few pics of the process.
That would appear to solve a lot of issues I see with the hitch situation on the Series 80.
Looks nice!
thanks, I'm no welder but it's doing the job intended. I didn't measure before and after but it gained quite a bit of clearance. It is off a couple degrees because I just started welding instead of tacking it the way I should have. I guess that gives it character.
Really nice job. I did almost the exact same thing because couldn't stand the tow hitch to be hanging so low.
I agree. I always thought it was kinda weird to see a built cruiser that still had that thing bolted under there. A hitch is a must-have so I figured why not get it as high as possible.
