Any help would be nice on how to remove the wiring harness.
Back on track....
First, the FSM method for removing the head assumes you are removing the head and intake as one unit. Most DIY guys do not take this approach because of the size and the wiring harness. So all the threads on HG replacement will show the intake removed before the head is removed. (at least the upper intake... some leave the lower.)
You have several options with the wiring harness. You can leave it where it is and unbolt the head, tilt the head toward the right side of the engine bay, then remove the intake bolts, and shove the complete upper + lower intake to the left side and secure with wire. Unfortunately, you cannot send the intake out with the head to be cleaned in the hot tank with the head so you'll have to clean it the best you can in the engine bay. One of alia176's HG jobs has a picture doing it this way. I think one of Doug's also has a picture. Those 2 guys have each done 3 HG jobs so finding their threads will take some looking.
Another option is to follow the FSM instructions and remove the wiring harness from the engine side (sensors, and tranny connections) which is a real PITA.
The best option to remove the wiring harness is to remove the connectors behind the glove box. They go to the ECM. Then snake it out of the cabin, into the engine bay, and out of the intake manifold. I think Alia176 just did his most recent HG job that way so send him a PM for instructions.
Another option is the way that Beno removed his by cutting a slot out of the intake brace, and removing the harness and permanently relocating it so that it no longer goes through the intake. He detailed the cut and the repair with pictures but he didn't show where he rerouted the harness. I think his method could be improved by cutting a much smaller slit with a hacksaw and running each wire through the cut, then sealing the cut with JB Weld. He had his big slot (large enough for the entire harness bundle) repaired with a tig. Either way is a bit on the crude side though (no offence to Onur.)
That should give you some ideas. Read Doug's HG thread because he shows pictures of how to leave the intake in the engine bay with the harness through it.
