I posted a question on a thread in the 60 series section by mistake (see # of posts) cause I'm new to the forum. I have a 79 FJ-40 with a 2-F. I started having trouble with the idle a few weeks back and it progressed to the point of shutting down whenever I would pull up to a stop light, etc coming off high rpms. I put a vacum gauge on it and after spraying a can of carb cleaner all over the engine I seem to have located my problem. I think it's the gaskets under the intake manifold (heat riser gaskets??). See If I'm on the right track. I pulled the carb and pulled all three of the bolts on top intake manifold. The one towards the front of the cruiser is clean. Pull the middle bolt near the block and it's clean. Pull the third bolt near the firewall and it's dirty as hello!! That's where I sprayed the carb cleaner and the engine rev'd. So I'm thinking the gaskets are blown near or around that bolt. Am I way off?
Thanks in advance!
TC
Thanks in advance!
TC
