Intake manifold stud broke
canada
Like a moron I accidentally over torqued the top left hand bolt on the throttle body and snapped the end of the stud. From the diagram, it looks like this stud is attached to the manifold and I should be able to replace it. Can someone confirm?
You may be able to use a bolt the same length instead of the stud.
Getting it out maybe fun . I would try reversed drill bit and/or extractor.
Lots of patience and maybe some PB Blaster!
I’m going to try and get it out when it warms up a little. But the diagram seems to indicate that the stud is not part of the manifold, I.e I won’t have to replace the entire manifold because of this mistake. I hope that’s the case.
