Instrument Cluster Restoration
I just take one part at a time Tom, whether its a major component or just a screw and concentrate on that until its as close to perfect as I can get it. It's when you slap it all together that it comes alive.
Here's the back door lock I just completed. I replaced the plastic handle with one from an aftermarket unit. The OEM part is a much better product, stronger and thicker spring, just generaly better built. Also the aftermarket lock is not 100% correct in dimensions. No problem with fit though. Still have to drill the hole for the retaining pin in the handle.
Nice work Teebag!
CrusieTheLand, no plating isn't hard.
Check this thread:
https://forum.ih8mud.com/40-55-series-tech/307072-yellow-zinc-cad-plating.html
