Instrument cluster removal 90s
are you talking about one of the indicator lights? If it is, I need the answer too, I noticed this week that the "D" isnt illuminated anymore.
Its a piece of cake.
There are 4 screw to remove the plastic panel where your knees are. Then the piece that sits above the steering wheel can then be removed without using any tools. From there you will remove 2 screws for the black instrument bezel. That bezel you need to be gentle with and the trick is to remove it from the TOP first. Once out you can see the 4 tabs and 4 screws holding in those tabs. Take those out and the cluster can be taken out. Now...to remove the cluster you need to lie the cluster on its back, then reach your hand behind and unclick the tabs holding each of the three sockets. One blue, one brown and one white. Each is a different size and therefore impossible to get them pushed into the wrong hole. Once you disconnect each connector you can then pull the cluster out. Be careful not to scratch or drop the cluster. Bad things happen.
What I recommend is to remove all the circular light tabs and check for burned out lights. Then for the center section you just need to depress the tabs on both sides and pull the center section up. Kinda tricky at first.
A "No D light club"? Can I get a window sticker for that? I dont think I want to got thru the hassle, no matter how easy, just for that, but maybe someday. I'll bookmark this for now, thanks NLXTACY.
My D light has been out for 9 years....no biggie.
Actually, all of them are out. ECT, too.
But the weird thing, on the climate control panel, the top two buttons to the left dont get any light until I hit the recirculated air button, then I can see them.
I need a whole set of bulbs, the gauge mod for temps and to install switches for lockers and CDL and the pin 7 mod still anyway.
...one of these days....
