I replaced my original 18 yo steering damper with a OME damper. Feeling the road too much with the addition of bigger tires.
The original removal was straight forward with the aid of a tie-rod puller. My question concerns reinstalling the OME mounting pin. Does the flange of the mounting pin need to be flush with the axel bracket and tie-rod end? If so, how to tighten both nut ends of the mounting pin to get the flange flush? I used two ratchets and wedged the top ratchet against the frame. Tightening the lower nut eventually turned the pin and tightened the upper nut.
I thought of using my tie-rod puller tool to push the OME mounting pin flush but there is not enough travel on my tool. (could borrow one).
Second question: I got 6 to 8 quality ratchet pulls per side (cannot pull any harder) how safe or unsafe is this for normal road driving? Ranging from "don't drive" to "get it done this week." Or is it good as is?
