One way to get it done would be to measure the distance between the upper and lower shock mounts with no weight on the particular side being measured(have your cruiser supported under the frame, high enough so there is no load on the springs), this would would be full droop. To get a full compression measurement; jack up the end of the axle where you're doing the measuring until the tire contacts sheet metal or the spring hits the bump stop, then measure the distance between the shock mounts. Do this at each corner of the rig, then you'll have measurements that can be referenced to find the proper shocks for your cruiser.
