- Joined
- May 11, 2008
- Threads
- 16
- Messages
- 262
- Thread starter
- #21
Mine looks to be ok, however where it mounts does look ****py should be a cover there. As for the silicone i used very lil and have had no problems lots of rain since install too. Not sure bout the bolts the rack comes with i think mine have already started to rust a little after only a few weeks may have to look into better ones that wont rust. I also got the lights mounted never had to take rack off and they fit perfect in the holes that were already there just had to get 4 big ass washers for the bottom so the nuts cant fall through.
Cool. I noticed that the front bolts (washer) actually cut INTO the fit kit and was rusting the day after. Not really a problem, but I looked at ALL the washers and NONE of them were perfectly flat...I think they gave me some super cheap washers. Not too worried though, I used TONS if black gasket-maker silcone. I'm very curious as to if we can modify the stock "cover ups" to go over the arb fit kit and cover up the eye-sore. Also, I think if I tried I could still turn the bolts some more...but I'm very worried about stripping the heads off so I think I'm good...the main thing is the washer actually CUT INTO the fit kit which I didn't even think was physically possible for a tiny piece of metal like that to slash into that zinc coated metal fit kit area.
I'm thinking another way to cover that hole up would be to buy some rubber, custom cut it, paint it black (or the color of your roof, mines black) and then silcone it down which would also make one hell of a seal.
