?????Installing a Parking Brake?????
Ran a quick search here: https://forum.ih8mud.com/search.php?searchid=1464734 I do remember reading about a lot of options, but most like the brake of the TC. If you are doing rear Disc, you can use the Eldorado caliper, but I have not seen where anyone has been successful in making this mod work 100%.
GL
Pete
why not run a line lock its easy and quick to set up, Also I was told last year that if you Made Chocks that were the right size for your tires they would let you run with that.
Are you running a stock LC one-piece TC? If so, just use the stock PB. I think Cruiseroutfitters.com has the right length cable for an automatic.
GL
Ed
It is just a drum brake, cable operated. Backing plate bolts to the four holes around the rear output shaft, drum fits on the splined shaft.
GL
Ed
