installin 2F
City that rhymes with fun
i have a 78 2f im lookin too swap into my 67. i plan on keeping the 3speed in it. is it just a simple drop in and bolt it all up or is there somethngi i am missing?
I'm running a 76 2f in my 65. It was pretty simple.
yah i knew i would need all that in place. thanks for the info im pretty pumped to get the new engine in. one other thing i wanna check compression on the new 2f before i swap it in what would be the best way to check while the engine is out. i probly already know the answer but jus was wondering what you all had to say.
You won't get an accurate compression measure without the engine being up to temperature. You can check the compression cold and compare it to others who have done both cold and hot checks to get a rough idea where it may be when it is hot.
Since you are not able to run it, I would just drop it in, see what you end up with and go from there.
You might want to replace the rear main seal while the engine is out. I did a f to f swap two years ago and wish I'd done that and the clutch along with it. I know, everyone told me to do it, but I figured it was probably fine based on what the PO said. Now I'm adding oil every now and then :)
Did the 67's come with power brakes? My 66 didn't and I have a mini truck conversion. Got the motor out and the 2F in when we figured out there was not enough room for a carb.:doh:
