Installed spring height?
Dallas
Hey guys,
I'm building a custom suspension for my 80 and I need some information. I've been searching the threads but can seem to find it.
Can anyone give me the installed height of their front and rear springs? Preferably newer 3 inch lift springs, but I can make adjustments if it's a different lift.
I need to know what the distance is from the upper and lower spring mounts with springs installed, and vehicle on the ground, without an extra load on the vehicle's suspension.
Any help is greatly appreciated!
Dobinson springs, the set I have give about 3.5-4 inchs. Little weight they will drop.
Look in the vendor area, Guys are nice and know the springs. They ride like a DREAM! Dobinson will cost more then OME but get you closer to the height you want and a much better ride.
What are you looking to do?
Thanks for the info, but what I really need to know is what is the total spring length, measured while installed on the vehicle under normal load.
I'm actually going to build an adjustable, long travel airbag suspension to handle heavy loads and to be able to have better on road characteristics.
Top of the page is a 'sticky' thread. Complied 80 series suspension and.... has so many measurements of trucks suspensions. Try to search just that thread and I bet you'll find what ever your looking for. Likely been posted elsewhere too but gonna be harder to shift through all those posts.
