Insert/Remove Birf Axle with Flat Spot Up
NJ
I am wondering what is the purpose of remove/insert front axle with flat spot on as suggested in many writeup. Of course, it is nice to have the axle put in the same way as it was taken out, which is what I intended to do. Nevertheless, I took out mine with flat spot on 3,9 o'clock, but had hard time to put in the same way (I probably did not try hard enough), so I rotated 90 degree with flat spot up, and it was in.
Having looked at splines on the end of axle, I had never noticed any difference. I am just curious whether it really matters with 'flat spot up'?
Are you sure you took them out with the flat spots at 3 and 9? You werent laying down were you? :D Mine wont come out any other way then 12 and 6. I think the only purpose is removal and assembly. Theres no reason to install in the same orientation, it spins in there dude.
Great, that is what I want to hear. I am pretty sure that I was not lying on my side :lol:, however it did slip off my greasy hands, it might have disoriented at that point...
