rear axles arent "inner axles" theyre just axle shafts. front axle has inner axles that go from spider gears to birf. rear axles go from spiders to wheel.
Hopefully your rear axle doesnt is a centered pumpkin or you might be screwed.
As for the swap of offset axles, you need later axles with fine spline. there are two different bearing styles, not sure if they can be swapped or not. sometime around 1972 they changed the axle shaft and bearing race. you should be able to swap the bearings if need be to the later style to run with post 72 axle shafts.
