inner axle splines
Atascadero, CA
i need to knwo if a late model third member (with the higher gears) will fit in a early model housing wiht early inner axles. i have a freind who is going to get a set of 79 axles and he wanted to put the front third on his housing because he has wilwood disc brakes. then he would use the whole rear axle so the gears match. i wanted to take the front housing if he does that because i want disc brakes. both of our cruisers are '72. the axles are '79. i didnt know if the slpines on the inner axles are the same.
let me knwo if this is even possible
thanks
-miles
yes
splines at the side gears from 1968-....hhhhmmmm....thru hhhmmm 1997?? (or maybe even the 100-series) are ALL 30-spline
thanks alot for that info. that is awesome.
thanks
-miles
