Inner Axle Oil Seal Question
Hello People,
This is my first or second post that I can remember after being looki-lou for some three years or so. I have been on this site probably everyday during that time. Always entertaining and educational.
Well, I am doing my first front axle job- my 1997 FZJ80 has been on jackstands for a while now. My question right now is regarding the front axle oil seals which I have installed but have noticed the "wound springs" that are supposed to be in the oil seal are loose and about. Is there any way to put those buggers back in while the new oil seal is seated? I have tried but with no luck. Do I need to buy new ones and re-install.
Do you reckon I smacked those oil seals to hard initially causing the springs to dislodge.
Any info or suggestions anyone may have is greatly appreciated.
Thank you,
Ken
Welcome.
My question right now is regarding the front axle oil seals hich I have installed but have noticed the "wound springs" that are supposed to be in the oil seal are loose and about. Is there any way to put those buggers back in while the new oil seal is seated?
Nope.
Yep.
Very likely.
Pack the backside of the seal with grease to prevent the spring from falling off....
-OR-
Pick up some of Marlins new inner axle seals and don't worry about knocking a little spring loose from the seal.
:beer:
Thanks
Hey,
Thanks so much for the quick reply. The Marlin's may be the way to go- More fool proof it sounds like.
Ken
I never had a need to try it myself, but come to think that there might be a chance that you can put the ring back on with help of some grease in the back area. (no offense poser.) I would give a try for 5-10 minutes - what you get to lose? Though, I can't tell how much faith you have left on this seal, might as well go for a new one if you prefer.
